gearbox
scorpadave
Hi Everyone,
I'm new here and new to scorpas.
I have an 05 SY250 I want to change my gearbox oil. I see there is a main drain plug on the bottom 12mm and a small level check on the brake pedal side. but what is the other drain plug on the under the gear lever?
Also how much oil should I put with 5 litres of fuel.
Thanks.
It's a blind plug for neutral switch.You don't have to lose it.
TY250Z had Japanese domestic-oriented specification named as TYZ250S.
Those crankcases were common parts. So,SY's crankcase has same plug too.
And,don't confirm oil level with a small check bolt on the brake pedal side.
Because the installing angle of the engine is different, it is not possible to be based on it.
You should manage the oil level by a regulated amount of not 650ml described in the crankcase cover but 550ml.
Thanks for your knowlege
