Sidecar Advice
lakelandramblers
Pretty sure its a Bruce Rushton chair, you should be able to contact him, he has links on the sidecar trials sites ie facebook, sidecar trials .com.
Good luck
Thanks for the info, I have been back in the garage, clouted things a little harder and got them apart. I found two needle roller bearings and a stepped pivot shaft, which is well worn. The bearings are no problem, but the shaft is a job for someone with a little more precision than a MIG welder and angle grinder. :thumbup:
