hop blip and a jump Posted September 7, 2011 Report Share Posted September 7, 2011 (edited) How much oil goes in the gearbox in a 2007 sherco 290?? Edited September 7, 2011 by hop blip and a jump Quote Link to comment Share on other sites More sharing options...
ormplus Posted September 7, 2011 Report Share Posted September 7, 2011 450cc of light gear oil . Quote Link to comment Share on other sites More sharing options...
hop blip and a jump Posted September 8, 2011 Author Report Share Posted September 8, 2011 Thanks. Quote Link to comment Share on other sites More sharing options...
geodet Posted September 8, 2011 Report Share Posted September 8, 2011 somewhere in the forum it has said use automatic transmission fluid (ATF) Sounds odd to me Why would you want to? Anyone care to comment. Quote Link to comment Share on other sites More sharing options...
cabby Posted September 8, 2011 Report Share Posted September 8, 2011 somewhere in the forum it has said use automatic transmission fluid (ATF) Sounds odd to me Why would you want to? Anyone care to comment. I use atf in mine, and has been fine and dandy Quote Link to comment Share on other sites More sharing options...
copemech Posted September 9, 2011 Report Share Posted September 9, 2011 ATF does work. Makes the clutch a bit more snatchy as compared to the thicker gear oils. Far as I have seen, 10-40 is still the factory recco. Translating that into a light gear oil is difficult because they use a different scale that equates to 75W or 80W or such. The thicker oils tend to keep the clutch a bit more progressive, but it seeme to me that it is more prone to the "cold stick" issue as well. It can be difficult to really get heat into the motor on a cold day in an effort to get things flowing as well. So a lot may depend upon what you want and your usage. Quote Link to comment Share on other sites More sharing options...
