Beta Cutting Out
hamster
Hammy - is it possible that you didn't get the woodruff key installed, or it slipped out when you re-installed the flywheel? If the flywheel is slipping on the crankshaft you'll have problems similar to what you've described.
jjWhite - judging from the vast number of posts you've submitted, and from your thoughtful response to hamster's problem you would be much more helpful if you grab a women's underwear catalog and go get ahold of yourself - come back and contribute when / if you get a job, or when / if you can grow facial hair. :)
Hamster, I had the same problem during a trial on saturday although i've not interfered with the flywheel weight.
The bike would idle for a short time then just stop.
This may sound too obvious, but have you changed the plug?
Once i changed mine on saturday it ran fine again.
An old friend of mine had a Beta flywheel weight catastrophe when he used slightly too long allen bolts to secure the weight. Make sure your bolts are not over long because they scrape on the vital stator coils. Jay
