efi64 Posted September 10, 2011 Report Share Posted September 10, 2011 Hi, I have a 2001 TXT 280 (not PRO). Does anyone know the ignition stator OHM values ? Thanks Quote Link to comment Share on other sites More sharing options...
richt Posted September 11, 2011 Report Share Posted September 11, 2011 Hi, This link shows the wire diagram for all 2001 TXT's, it says between the Light Blue and Dark Blue wires should be 100.5 ohms. http://www.gasgas.com/Pages/Technical/Electrics/wiring-kokusan-2001-txt.html Quote Link to comment Share on other sites More sharing options...
efi64 Posted September 11, 2011 Author Report Share Posted September 11, 2011 (edited) Thanks, I missed that. Edited September 11, 2011 by efi64 Quote Link to comment Share on other sites More sharing options...
efi64 Posted September 13, 2011 Author Report Share Posted September 13, 2011 I have some more questions regarding the 2001 ignition system. Is the sparkplug cable replacable ? It doesn't seem to want to move out of the coil. Is it possible to replace the copper cable with a ceramic cable ? Quote Link to comment Share on other sites More sharing options...
jse Posted September 13, 2011 Report Share Posted September 13, 2011 I have some more questions regarding the 2001 ignition system. Is the sparkplug cable replacable ? It doesn't seem to want to move out of the coil. Is it possible to replace the copper cable with a ceramic cable ? I think it has a strong adhesive to hold it in. If you clip off about 10mm from the end of the wire, you will have a new, clean wire contact area for the plug cap to screw in to. Jon Quote Link to comment Share on other sites More sharing options...
