What Montesa did I just buy?
charliechitlins
21M25425
Has some different stuff from my '74 which is also a 21M.
Clutch arm on top, different engine covers, Amal carb...
The guy I got it from tied it down to bring it home and when he took the straps off, the forks stayed collapsed.
Any Ideas.
The seat/tank is a WRECK.
What are we doing with these things these days?
I still figure I did OK.
Buying bikes from rednecks is interesting.
He took $375 and a 30-pack of Busch.
It's a Cota 247 "C"....somewhat rare in the USA. Older Montesa forks will stick after sitting for a long time. Take them apart, use a broom handle and hammer to push out the damper rods. You will see the aluminum bushing on the damper rods have "swelled" and need to be turned down a wee bit. Looks like aftermarket shocks. The tank can be fixed, the rest of the bike is not bad. Does it run?
The serial nimber 21M25425
25K+ that is a lot of 247 Cotas
Nice find. Make it a runner and ride it.
I'll give you $400 for it and two Busch 30 packs
Edited by for artie
  On 9/19/2011 at 1:18 AM, charliechitlins said:
Thanks, Shaun!
So...how are we fixing these tanks these days?
This ones cracked, delaminated, etc.
Don't need beautiful, just so it doesn't leak.
Sammy Miller in UK has 348 tanks new - it looks close so may be able to modify. I got hold of a brand new tank and seat a guy had in his garage - it was a 247 unit but I still had to make rubber spacers for mounts as it was wider than the original.
Try John@rmmontesa.com Rocky Mountain Montesa - John has been able to help we with several hard to find parts.
Completely different. The seat base on the 348 points downwards, on the 247 it's horizontal.
I think those tanks on SM are just the covers as per the UK model.
*edit* yes it is: 348 tank cover
Edited by TooFastTim
  • 1 month later...
