youthy Posted September 20, 2011 Report Share Posted September 20, 2011 Hi all after a long time of reliability my 03 250 pro has developed a running problem. Seems to cut out at random feels asthough ive stalled it when it does however when its cuts out it looses spark and does so for roughly 10mins and will not spark again for roughly the same time. Its not the plug as ive been taking a spare to trials with me however its getting quite unreliable now. Anybody got any ideas as to what this can be? I have tried removeing tank checking all wiring for defects and made sure all plugs etc are clean and have good connections, i have also run the bike with wiring all pulled out and bent wires wiggled plugs etc and runs ok. even ran in the dark to see if i could see anything shorting out but with no joy! Quote Link to comment Share on other sites More sharing options...
stecks Posted September 20, 2011 Report Share Posted September 20, 2011 I used to ride an OSSA (I know, I was young...) and it developed an intermittent cut out fault. I was lucky, I found it fairly soon. One of the cables fed a spade connector on the Motoplat HT Module (coil?), and it had a moulded plastic shroud over the push on spade connector. This (copper coloured, brass looking) spade connector had snapped inside its plastic shroud. The shroud held it in place for a time, and as the engine revved, the contact could make or break as it felt the need. My Dad was an electrician and he suggested following every cable, and checking for continuity using a meter. We did this and found that the feed to this spade connector was intermittent. It would make a break depending on movement of the cable, and it ran OK for a short while until perhaps vibration caused the metal to part. Try a continuity multimeter (one with a buzzer or a light) on all the cables and see if you can break the continuity by bending and twisting cables. You will just have to be methodical and eliminate all cables. Hope this helps. Quote Link to comment Share on other sites More sharing options...
g14gav Posted September 21, 2011 Report Share Posted September 21, 2011 Could be a blocked or faulty tank breather pipe, could be that there's not enough air getting in and creating a vacuum, after leaving bike for 10mins enough air has been drawn in for carb to refil... Just a simple one to check Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted September 21, 2011 Report Share Posted September 21, 2011 If it were a Beta or Sherco i would say its the stator, unusual for a gas gas, but certainly possible, can't be blocked fuel hose if the spark disappears. Quote Link to comment Share on other sites More sharing options...
g14gav Posted September 22, 2011 Report Share Posted September 22, 2011 On 9/21/2011 at 8:23 PM, t-shock 250 said: If it were a Beta or Sherco i would say its the stator, unusual for a gas gas, but certainly possible, can't be blocked fuel hose if the spark disappears. True Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted September 23, 2011 Report Share Posted September 23, 2011 When a coil is going tits-up it will often cut out when it warms up, after a few minutes of running. Quote Link to comment Share on other sites More sharing options...
