andy m Posted September 21, 2011 Report Share Posted September 21, 2011 Is there anything to do to a BSA Bantam front hub(std D14 / B175) before it goes to be laced to a 21" rim. I have the rear sorted (widened) just don't want to get it laced to find out I should have done something. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted September 21, 2011 Report Share Posted September 21, 2011 Is there anything to do to a BSA Bantam front hub(std D14 / B175) before it goes to be laced to a 21" rim. I have the rear sorted (widened) just don't want to get it laced to find out I should have done something. Thanks in advance. Paint it, get the drum skimmed ? Quote Link to comment Share on other sites More sharing options...
twinshock Posted September 22, 2011 Report Share Posted September 22, 2011 And make sure the rim has the same number of spokes as the drum Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted September 22, 2011 Report Share Posted September 22, 2011 And make sure the rim has the same number of spokes as the drum LOL you done that too ? Quote Link to comment Share on other sites More sharing options...
esteve Posted September 22, 2011 Report Share Posted September 22, 2011 What spoke gauge do you want to use? Check the hub will accept the gauge you want to use. For a trials application on Cubs, 10 gauge (3.2mm) is standard. Many of the Bantam hubs which look the same as the Cub hub will only take 12 Gauge (2.6mm) spokes. Quote Link to comment Share on other sites More sharing options...
