bondy Posted September 21, 2011 Report Share Posted September 21, 2011 hi all without going down to my shed. and checking whats the nut size on the front wheel spindel? is it 17mm oh sorry its on a sherpa 350 199A the nut with the flange. only reason im asking is i need one for anougher bult ill be restoring. ive seen a new one off a yamha ty 250 but thats 16mm cheers bondy Quote Link to comment Share on other sites More sharing options...
bullylover Posted September 22, 2011 Report Share Posted September 22, 2011 Hello Bondy, The front axle nut on all of the later Sherpa T`s are 15mm. I am not sure what they are on the first few models but I know from the M80`s on they are the same at 15mm. Good luck. Bully Lover. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 22, 2011 Report Share Posted September 22, 2011 if you have a normal 15 socket it needs to be ground to give clearence to get in. Quote Link to comment Share on other sites More sharing options...
bullylover Posted September 22, 2011 Report Share Posted September 22, 2011 What I have always used is a 3/8th drive 15 mm socket as they slide right in. Quote Link to comment Share on other sites More sharing options...
bondy Posted September 22, 2011 Author Report Share Posted September 22, 2011 What I have always used is a 3/8th drive 15 mm socket as they slide right in. thanks guys Quote Link to comment Share on other sites More sharing options...
