09 cabes replica fork oil volume?
johnson
Hey guys, I own a '09 cabestany replica 290 and have recently sprung a leak in the left fork leg...Someone told me that it holds 330ml but someone else told me to fully compress the leg and top it up 120mm from the top? Any ideas on what method to use would be appreciated! thanks :thumbup:
The left fork on that year model holds 385ml from empty.
If I gotta pull one down to change a seal anyway, is just seems easier to me to put 385 back in.
The right (damper)side is different at 370, but you gotta remove the damper and pump it dry to get all the old oil out or you will have a problem. :thumbup:
