luct4 Posted September 22, 2011 Report Share Posted September 22, 2011 Hello afther 2 years off 2T riding i bought recent the EVO 300 4T. I'm concerned for the location of the ignition box / CDI. The box is located verry low down on side of the engine. I don't think this is a great place for riding in the water, mud,... Does anyone relocated the box?? I would like to know more about it. Thanks & greathings Luc The Belgium rider. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted September 22, 2011 Report Share Posted September 22, 2011 A couple of years ago some guys put the unit behind their Number board Quote Link to comment Share on other sites More sharing options...
scoobydo Posted September 23, 2011 Report Share Posted September 23, 2011 A couple of years ago some guys put the unit behind their Number board Best place and easy to do is re locate it just above the top of the clutch side casing - on a level with the carb. You can use the same mounting bracket too. This reminds me..... I need to move mine too ! Quote Link to comment Share on other sites More sharing options...
luct4 Posted September 23, 2011 Author Report Share Posted September 23, 2011 Best place and easy to do is re locate it just above the top of the clutch side casing - on a level with the carb. You can use the same mounting bracket too. This reminds me..... I need to move mine too ! Thanks for the answer. Do you now iff i need to enlarge the cable? Greathings Luc Quote Link to comment Share on other sites More sharing options...
jsp Posted September 23, 2011 Report Share Posted September 23, 2011 i made a small bracket as i couldnt get it to work with out one jsp Quote Link to comment Share on other sites More sharing options...
benzman113 Posted September 30, 2011 Report Share Posted September 30, 2011 i did this too all you need to do is mount at side of carb no need for cable extention just turn mount box round it works, stop the water ingress/backfireing.doddle 2mins Quote Link to comment Share on other sites More sharing options...
