sectionone Posted September 22, 2011 Report Share Posted September 22, 2011 I've was having trouble with my clutch when going very slow/stopped with the clutch disengaged or slightly dragging. Often, the point where it is slipping and engaging will be abrupt, not smooth. I was reading the sticky in the Beta forum about improving the clutch and know about the clutch basket filing method used for enduro and mx bikes. GG has a steel basket and I noticed very subtle grooves worn in the basket. The pull is as light as new and thickness is within specs. The clutch plate tabs were a bit rough, which I suppose is how they come from the factory. I did a very light filing on the basket and a super light filing on the plate tabs and the clutch abruptness went away. I didn't take the clutch pack apart. I also think just taking the clutch pack out of the basket and rotating in to another position might work as well. Quote Link to comment Share on other sites More sharing options...
