scott_king Posted September 25, 2011 Report Share Posted September 25, 2011 Hey all Encountered a problem today. Started the bike in the garage yesterday without any problems so went to the trial today and now the bike wont't start as I have no spark. Took the bike home and stripped it all down, replaced the plug, checked all the connections for continuity and everything voltage wise is in spec with the numbers in the manual. No connections were corroded or dirty. I pulled the bank sensor and checked that as well. As far as I can tell everything is fine. It should have a spark as I have ruled out everything in the manual, condenser, coil and rectifier etc but it simply will not spark. I plugged in the PGM diagnostic tool and that failed to identify the problem. Anyone have any additional ideas? Thanks Scott Quote Link to comment Share on other sites More sharing options...
pandelboy Posted September 25, 2011 Report Share Posted September 25, 2011 faulty cut out switch earthing itself out ?? disconnect and try again/ Quote Link to comment Share on other sites More sharing options...
scott_king Posted September 25, 2011 Author Report Share Posted September 25, 2011 On 9/25/2011 at 4:53 PM, pandelboy said: faulty cut out switch earthing itself out ?? disconnect and try again/ I disconnected that at the track. I have know a few to go south in the past so that was my instinct. But thanks for suggesting it. Quote Link to comment Share on other sites More sharing options...
munch Posted September 25, 2011 Report Share Posted September 25, 2011 is the tilt sensor still fitted ? Quote Link to comment Share on other sites More sharing options...
jj65 Posted September 25, 2011 Report Share Posted September 25, 2011 Cut out switch, is that the stop button, what about the tilt sensor, Or have you removed that? Quote Link to comment Share on other sites More sharing options...
scott_king Posted September 25, 2011 Author Report Share Posted September 25, 2011 On 9/25/2011 at 7:19 PM, munch said: is the tilt sensor still fitted ? I have taken it off and had a play with it. I can hear it clicking from one side to the other. I am getting resistance across the connections but I have no reference to see if the switch is within tolerance. I was going to try and wire it out of the circuit tomorrow to 100% rule it out. Any idea how I would do this?? Quote Link to comment Share on other sites More sharing options...
stkman Posted September 25, 2011 Report Share Posted September 25, 2011 I had a similar problem with my 4RT ... running fine at a trial. Stopped, leaned bike into a bank (no stand) and wouldn't go when picked up. Pulled plug out and checked, no spark. Turned out to be throttle cable pulled put at the throttle body (was holding throttle slightly open). Popped it back and spark was back! Started first kick. Spent hours on it and that is what it was!!!! Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 25, 2011 Report Share Posted September 25, 2011 Easy way to check angle sensor. Remove bank angle sensor, join outside wires together in the block connector to bypass the switch, try to start. Another problem i have had was caused by damaging the protective sheeving on the wiring loom between the stator and rectifier which allowed water in to cause a short Quote Link to comment Share on other sites More sharing options...
scott_king Posted October 5, 2011 Author Report Share Posted October 5, 2011 Hey Guys Just to let people know for their future reference I never actually found a problem. No faulty coil or bank sensor or even a dirt connection. I simply checked everything cleaned all connects even though I didnt find any dirt or water and now the bike starts first kick. Very frustrating that I never found a problem but hope this could help people in future. Thanks Quote Link to comment Share on other sites More sharing options...
