plichhayy Posted September 26, 2011 Report Share Posted September 26, 2011 hey all just got into trials n jus got my new bike..now some dude that had it before me needed to replace carb parts, but the mechanic he had workin on it changed out the choke jet with plyers and striped the numbers off the end , im jus wondering if anyone has the bike or knows what the number jet is i need to be running, the dealer said thers millions of diff ones and without the number its guessing blind, he sent me one he thought would be best suited to my bike, but still doesnt idle down correctly , bike works fine and is ride able its jus annoying listenin to the idle when i grab the clutch, thanks for your time also my bike is a 1994 montesa cota 314r 250cc if im not mistaken ? Quote Link to comment Share on other sites More sharing options...
plichhayy Posted September 29, 2011 Author Report Share Posted September 29, 2011 nobody got this number for me or any idea what would work ? Quote Link to comment Share on other sites More sharing options...
copemech Posted September 30, 2011 Report Share Posted September 30, 2011 What carb is onit? Normal new dellortos come with a #60 choke jet, but none of that should have anything to do with the running off choke, just need to insure it is clean. Pilot jets may be another story! Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 30, 2011 Report Share Posted September 30, 2011 you should only be using the choke jet when the engine is cold, probably for first 30 seconds to a minute, after that the choke should be turned off. Are you sure its the choke jet your talking about ? if its not idling when warm turn the choke off, if its off already then the pilot jet is your problem or somthing else is wrong. Quote Link to comment Share on other sites More sharing options...
plichhayy Posted October 14, 2011 Author Report Share Posted October 14, 2011 yes i now understand that it wouldnt matter..jus the guy i bought it off was calling it the choke jet so i went n posted rite away as i was anul n wanted the bike to be perfect .. haha after driven fora while the bike works fine like perfect i cant notice any ill effects , so ima jus pound on it until next season and buy a new one (scorpa sy280)and use the monty as a buddy bike or trail mission bike hahah puta a seat or something ... thanks thou guys Quote Link to comment Share on other sites More sharing options...
