tomf Posted September 29, 2011 Report Share Posted September 29, 2011 I'm going to replace my original 315r clutch plates with Apico steel and fibre plates at weekend, just wanted to know should I soak the plates in elf oil before installation or will I just rub some oil around them before I put them in? Also what torque should I tighten the casing up too when I'm done. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
copemech Posted September 30, 2011 Report Share Posted September 30, 2011 I'm going to replace my original 315r clutch plates with Apico steel and fibre plates at weekend, just wanted to know should I soak the plates in elf oil before installation or will I just rub some oil around them before I put them in? Also what torque should I tighten the casing up too when I'm done. Thanks for all the help. To be honest, I am not sure what response one will get from the M/C croud on this, but having builta lot of clutch packs for automatic transmissions, I allways soak the friction plates for a bit, if nothing elst but to insure things are properly lubed up on startup. Quote Link to comment Share on other sites More sharing options...
tomf Posted September 30, 2011 Author Report Share Posted September 30, 2011 To be honest, I am not sure what response one will get from the M/C croud on this, but having builta lot of clutch packs for automatic transmissions, I allways soak the friction plates for a bit, if nothing elst but to insure things are properly lubed up on startup. Cheers mate sounds good to me. Quote Link to comment Share on other sites More sharing options...
