taylo63 Posted September 30, 2011 Report Share Posted September 30, 2011 Hi all I'm thinking of removing the swinging arm from my 07 sy250 just to clean and regrease bearings etc. I would like to know if there are any gotcha's I need to be aware of when doing so. Thanks in advance for your advice. Paul. Quote Link to comment Share on other sites More sharing options...
thespikeyone Posted September 30, 2011 Report Share Posted September 30, 2011 make sure you don't loose the nylon washer thingys. and be careful when you are removing the sw/arm not to lift it too high and end up shearing the rear brake hose where it bolts to master cylinder. other than that its pretty simples Quote Link to comment Share on other sites More sharing options...
