theotherone Posted September 30, 2011 Report Share Posted September 30, 2011 Anyone know how to get the forks apart on a mini trial? Need to replace the fork seals. Removed the top fork cap and pulled out the spring. Need to undo the bolt that's located at the bottom of the fork, but how do I stop the internals from spinning? I guess there's a "special tool" for this. Anyone out there got any ideas? Quote Link to comment Share on other sites More sharing options...
boni_tou_1 Posted January 10, 2012 Report Share Posted January 10, 2012 if you use an air gun or impact driver on thhat bottom nut should get in off, if their are like most forks should be a you tube of how to do this Quote Link to comment Share on other sites More sharing options...
