muffin Posted March 28, 2005 Report Share Posted March 28, 2005 Hi Picked up a new Mont 4RT the other day. Yesterday I changed the oil filter and replaced the engine oil as per owners manual. Started the bike afterwards no problem. Just gone to start the bike again and can't get it going at all. Any ideas on what to try to get it going again? Cheers Muffin Quote Link to comment Share on other sites More sharing options...
o.a.s motorcycles Posted March 28, 2005 Report Share Posted March 28, 2005 I now you have already done it but if you haven't make sure you do the 4 light pushes on the kickstart to charge it before starting it. Other than that i'd take it back and get it sorted concidering how expensive it is Quote Link to comment Share on other sites More sharing options...
muffin Posted March 28, 2005 Author Report Share Posted March 28, 2005 Yep, done the charging kicks first. It started yesterday after I did the work, its been 24 hours where the bike has been stood on its side stand and now I am having bother. Bloody kickstand imbedded itself in my leg as well, my fault perhaps for not wearing proper boots, I guess its adding to my frustration!!:-) Quote Link to comment Share on other sites More sharing options...
o.a.s motorcycles Posted March 28, 2005 Report Share Posted March 28, 2005 then I'd get on the phone to who ever you got it from! You don't want to touch it to much as they get a bit arsey and think you've been messing with the electics. I'd stick with a good old carb myself oh well hope you get it sorted soon Quote Link to comment Share on other sites More sharing options...
the artist formerly known as ish Posted March 28, 2005 Report Share Posted March 28, 2005 Do they have the old style on off switch that honda uses Quote Link to comment Share on other sites More sharing options...
muffin Posted March 28, 2005 Author Report Share Posted March 28, 2005 Just checked the kill switch and the contacts are open so it can't be that. Quote Link to comment Share on other sites More sharing options...
jjwhite Posted March 28, 2005 Report Share Posted March 28, 2005 maybe you should check spark plug, its probably not dirty, but u may have a faulty one, i had problems starting mine and foun out it was the plug. failing that check the breather pipe, it may be that the fuel is simply in a vacuum and not reaching the engine. Quote Link to comment Share on other sites More sharing options...
muffin Posted March 28, 2005 Author Report Share Posted March 28, 2005 Thanks, I will check the spark plug and the breather hose. Infact the breather hose is really long and snakes round the handle bars and the end of it pokes out at the side of the left hand engine casing. The breather hose has a joining connection on it as well just above the fuel filler cap, is that right because people I have spoken to say the joining bit in the hose is a restrictor? Quote Link to comment Share on other sites More sharing options...
madmax Posted March 28, 2005 Report Share Posted March 28, 2005 (edited) Put a new spark plug in the bike.........Problem solved ....Madmax Edited March 28, 2005 by madmax Quote Link to comment Share on other sites More sharing options...
martin belair Posted March 28, 2005 Report Share Posted March 28, 2005 (edited) It may be that you have the idle turned down too far. The bike must idle at 1800 rpmin order to charge the capacitor and make it re-start. Please contact your dealer and ask for his help. Martin Edited March 28, 2005 by Martin Belair Quote Link to comment Share on other sites More sharing options...
woody Posted March 28, 2005 Report Share Posted March 28, 2005 As it is new, if I were you I'd go back to the dealer with it. If you mess with anything, no matter how simple, it may invalidate any warranty you have. Some dealers don't need much of an excuse. Even if it turns out to be something simple, best they deal with it rather than you end up paying through invalidated warranty. Hope you get it sorted. I tried a couple of 4RTs last week and liked very much. Very close to acquiring one. Quote Link to comment Share on other sites More sharing options...
bikespace Posted March 28, 2005 Report Share Posted March 28, 2005 Is it true that the type of spark plug for the 4RT is not your usual NGK readily available model? Or is that just a rumour! Big John It's not a spark plug, it's a glow plug in a diesel Flak jacket securely fitted Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted March 28, 2005 Report Share Posted March 28, 2005 Ooooh Bikespace...you naughty boy!!..fancy trying to wind people up like that!! Quote Link to comment Share on other sites More sharing options...
barcota Posted March 29, 2005 Report Share Posted March 29, 2005 (edited) Obviously I would follow Martin's advice and return the bike to the dealer. I had the same problem with my 4RT when I first got it so I can give you a couple problematic things to check out from my experience. 1. In the beginning I had a bad spark plug so I replaced it. 2. After re-routing the gas tank vent hose I found out that I inadvertantly re-installed the vent ball restrictor upside down. The white end must be mounted with white end facing the tank or the ball check inside will create a vacuum in the tank. 3. The bike will stop running when idling with the kickstand down. It has an angle sensor that shuts the engine down when the bike is leaned at a pre-determined angle for more than six seconds. When idling for the two to three minutes recommended don't use the kickstand or the bike will stall. 4. Always use gasoline with an octane rating of more than 90 octane. The engine has a high compression ratio and I have found it runs much better with the higher octane rating. 5. As recommended in the owner's manual you should never even touch the throttle when starting as it will foul up the pre-set settings in the computer. I hope these tips will help you. Would appreciate you letting us know the final cause after having your dealer check the bike out. I am very pleased with my 4RT and know you will also once you get by this little problem. Edited March 29, 2005 by barcota Quote Link to comment Share on other sites More sharing options...
lukass Posted March 29, 2005 Report Share Posted March 29, 2005 3. The bike will stop running when idling with the kickstand down. It has an angle sensor that shuts the engine down when the bike is leaned at a pre-determined angle for more than six seconds. When idling for the two to three minutes recommended don't use the kickstand or the bike will stall. Wow really? Anybody know what this is for? It would be a good idea to prevent oil starvation to the valve train if the bike is still running on it's side. Seems a little extreme to have it shut down at such a small angle though. I haven't seen any of these yet, can't wait to give one a try. Are they wet sump? Bucket and shim or rocker valve train? Quote Link to comment Share on other sites More sharing options...
