gii Posted October 17, 2011 Report Share Posted October 17, 2011 After a couple of minutes of 'difficult' gearchanges on my 4RT I managed to get it into 1st gear by rocking the bike with the engine off and selecting the gears by hand. Once into 1st it stayed there, the gear lever moves through its normal arc and is returned to the central position by the spring, but no longer feels like it is connected to anything. Any ideas what I should expect to find broken when I strip it? Quote Link to comment Share on other sites More sharing options...
ham2 Posted October 17, 2011 Report Share Posted October 17, 2011 (edited) Hi Gordon, Memory test time?? .... I recall someone else having similar symptoms to yours (I think the plate is welded to the shaft and it had fractured at the fillet)... although his bike had ,previously,been dropped and taken a whack 'full-on' to the shifter. Part no 18 was the suspect:- Click here go to E-14 Edited October 17, 2011 by HAM2 Quote Link to comment Share on other sites More sharing options...
