greencubba Posted October 22, 2011 Report Share Posted October 22, 2011 have a 59 c15t distributor model running points and capacitor ignition how do i replace the points gubbins with an electonic sensor do i need to fit a battery and buy a boyer black box and sensor or can u just get the sensor for mushroom and wire it into the capacitor ignition system which im assuming is 12 volt as its running a 12 volt capacitor. just want shot of the prince of darkness points so i can start the bugga easier ! hopefully !. anybody got a back wheel /hub with a bolt on sprocket to fit as its got a road wheel at mo and is too high geared, 46 shud be 56, sprocket is cast into hub. Quote Link to comment Share on other sites More sharing options...
b40rt Posted October 22, 2011 Report Share Posted October 22, 2011 (edited) Fitted Boyer many years ago,(to a B40) no battery needed, everything came with the kit. Easy to fit, time etc. Electrex also do a kit thats supposed to be good, as is PVL. Edited October 22, 2011 by B40RT Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted October 23, 2011 Report Share Posted October 23, 2011 Hi Guy's. You could try this link for information. http://www.trialsbits.co.uk/product_info.php?cPath=80_242&products_id=1027. Regards Charlie. Quote Link to comment Share on other sites More sharing options...
bashplate Posted December 13, 2011 Report Share Posted December 13, 2011 thats a neat set up . i was always under the impresion that boyers neaded a battery....how wrong was i . Quote Link to comment Share on other sites More sharing options...
jon v8 Posted December 14, 2011 Report Share Posted December 14, 2011 I would go for the Electrex world system which goes on the end of the crank,very accurate,reliable and invisible. http://www.electrexworld.co.uk/acatalog/STK-010.html Quote Link to comment Share on other sites More sharing options...
