Getting started
anthc123
Hi, I'm a first time trials rider and have just bought a 2003 beta rev 3 270. I am just looking for a little info really
What tyre pressures should I use
How often should I change oils and filters?
Is there anything I should check over befor I go out on it
General maintenance?
All info is much appreciated
Regards :)
Hi mate
I am fairly new to the sport to, here is what I do
Base setting for tyre's
Front 6-7psi
Rear 4-5psi
If it's soft and muddy you can afford to let a few pounds out of either.
Clean and oil air filter regular very important if not done will cause issues
Change oil every 6 rides ish
Check wheel bearings, nuts bolts etc as 2 strokes vibrate stuff loose, one to watch out for is the kick start bolt!
Clean bike after every ride and apply wd where needed
Other than that enjoy!!
