benwall Posted November 3, 2011 Report Share Posted November 3, 2011 Hi does any one know the standard Ty80 gearing on front and rear sprokets?, also what gearing does your ty80 have? Thanks Ben Quote Link to comment Share on other sites More sharing options...
bruno21 Posted November 3, 2011 Report Share Posted November 3, 2011 On 11/3/2011 at 5:59 PM, benwall said: Hi does any one know the standard Ty80 gearing on front and rear sprokets?, also what gearing does your ty80 have? Thanks Ben Hi, The standard gearing on a TY80 is 12 tooth front and 41 tooth rear that is what I put on the one I have rebuilt. Quote Link to comment Share on other sites More sharing options...
benwall Posted November 3, 2011 Author Report Share Posted November 3, 2011 On 11/3/2011 at 6:05 PM, bruno21 said: Hi, The standard gearing on a TY80 is 12 tooth front and 41 tooth rear that is what I put on the one I have rebuilt. Thanks Would you say that its a slow controlled gearing? as its for my sister and she will only be doing beginer sections at our local club which tend to stay on the flat with the ocasional small hill with tight corners Quote Link to comment Share on other sites More sharing options...
bruno21 Posted November 3, 2011 Report Share Posted November 3, 2011 On 11/3/2011 at 6:07 PM, benwall said: Thanks Would you say that its a slow controlled gearing? as its for my sister and she will only be doing beginer sections at our local club which tend to stay on the flat with the ocasional small hill with tight corners You might be better getting a smaller gearbox sprocket as it does seem a bit fast in 1st gear !! Quote Link to comment Share on other sites More sharing options...
benwall Posted November 4, 2011 Author Report Share Posted November 4, 2011 On 11/3/2011 at 7:19 PM, bruno21 said: You might be better getting a smaller gearbox sprocket as it does seem a bit fast in 1st gear !! Thanks Quote Link to comment Share on other sites More sharing options...
