bondy Posted November 7, 2011 Report Share Posted November 7, 2011 hi all ive just had my yoks powder coated dose anybody have any ideas on how to tighten it with out risk of damageing the paint? i no the nut as groovs in it for a c spanner but theres not enough space to get a c spanner in. so i got a normal nut of bultaco uk but im still dont want to damage the paint. allso how tight should this be? cheers bondy Quote Link to comment Share on other sites More sharing options...
pschrauber Posted November 7, 2011 Report Share Posted November 7, 2011 hi all ive just had my yoks powder coated dose anybody have any ideas on how to tighten it with out risk of damageing the paint? i no the nut as groovs in it for a c spanner but theres not enough space to get a c spanner in. so i got a normal nut of bultaco uk but im still dont want to damage the paint. allso how tight should this be? cheers bondy Make your own little washer, around 2 - 2,5mm thick out of aluminium and then the problem is solved. Bore should be 25,5mm, Diameter: 40mm. Quote Link to comment Share on other sites More sharing options...
bondy Posted November 8, 2011 Author Report Share Posted November 8, 2011 Make your own little washer, around 2 - 2,5mm thick out of aluminium and then the problem is solved. Bore should be 25,5mm, Diameter: 40mm. thanks mate Quote Link to comment Share on other sites More sharing options...
