Need advice please
durham4416
Iv got a beta rev3 and my sons got a beta minicross, while we were out the other day his bike cut out, It would only run if I revved it, whilst revving it I heard a pop and then it won't start, iv he is only 5 and dosnt ride it fast, iv just removed the engine and can't see anything obvious, the piston and rings seem ok as does the bore, iv replaced piston and rings in 2 strokes before but that's as far as iv been, anybody have any ideas what the problem may be, cheers James
First:
Check the plug for fouling
Then check for spark
Then check fuel delivery
Then check compression
Then change the plug anyway
Then test the plug cap resistance
Then pull the exhaust and look at the piston skirt
Unfortunately pulling the engine often leaves you in this situation where you can't check for spark of fuel delivery or compression so you did the last thing first
It's like if you get a flat you remove the tire without checking to see if the valve is leaking air
Tear down is not diagnosis, only tear down an engine AFTER you suspect a certain specific problem, you don't want to have the crankshaft on the bench when you find a piece of carbon on the spark plug or discover a stator problem
