pindie Posted May 11, 2012 Report Share Posted May 11, 2012 He could get away with no gears! Personally I need as many as I can get. A bit like my excuses. Quote Link to comment Share on other sites More sharing options...
samy Posted May 13, 2012 Report Share Posted May 13, 2012 My sherco feels like it needs a gear between 3rd and 4th. Getting around the loop between sections, 3rd is too low but 4th is too high... Anyone else with a sherco confirm this? Quote Link to comment Share on other sites More sharing options...
copemech Posted May 14, 2012 Report Share Posted May 14, 2012 My sherco feels like it needs a gear between 3rd and 4th. Getting around the loop between sections, 3rd is too low but 4th is too high... Anyone else with a sherco confirm this? Prolly true on a 250, as the gap is wide for woods work, yet the 2.9 has a bit more guts and is less likely to fall off the power. A tooth or two on the rear makes a difference, yet you will likely ride most sections in second gear, which is fine if you adjust to it. Seems a drop to 9 on front is just too much. Quote Link to comment Share on other sites More sharing options...
Guest gjbiker Posted May 14, 2012 Report Share Posted May 14, 2012 I 've got microsoft Word but that document is blank when I open it...a bit like me? Looks like this..... GJ Quote Link to comment Share on other sites More sharing options...
gjbiker Posted May 14, 2012 Report Share Posted May 14, 2012 That's weird, my last post there has me as a new member? Signed out and back in again and I'm me again? The gremlins are back........... GJ Quote Link to comment Share on other sites More sharing options...
ham2 Posted May 14, 2012 Report Share Posted May 14, 2012 Thanks GJ....to both of you That's the problem with schizophrenia... you're always the last to find out Or a bigger worry; was it your doppelgänger? Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 14, 2012 Report Share Posted May 14, 2012 That's the problem with schizophrenia... you're always the last to find out Surly you'd both be the last to find out ? Quote Link to comment Share on other sites More sharing options...
samy Posted May 15, 2012 Report Share Posted May 15, 2012 Prolly true on a 250, as the gap is wide for woods work, yet the 2.9 has a bit more guts and is less likely to fall off the power. A tooth or two on the rear makes a difference, yet you will likely ride most sections in second gear, which is fine if you adjust to it. Seems a drop to 9 on front is just too much. I am due for a new rear sprocket anyway as i noticed last weekend that i have several chipped teeth on my rear sprocket, which is a 42. Just to clarify, with the style of riding we have here in competitions there is very minimal 'trail' riding between sections (sometimes getting to each section is harder than the sections themselves ) and i don't think i've ever used 5th gear in the almost 12 months ive owned it. I occasionally use 4th just to give it a go but almost always immediately change back to 3rd because 4th labours too much. So realistically, i don't use 4th or 5th gear at all. When on my mate's 280 Ossa there's no problem as it has the extra grunt to just pull away without labouring. Also, i often find that 1st gear is too fast when i'm trying to navigate a tight section and second gear a tad too high for most climbs. I overcome this due the Sherco's suburb clutch which i feather through most sections... i love that clutch... Looks like i'll be ordering a 44 sprocket. Sounds like just the thing i need to suit the terrain we ride. I just hope the 44 sprocket makes enough of a difference because the 4% difference or whatever it is doesn't sound like much. I have the stock chain, is there likely to be any issues with the chain having enough length? And also the hardest part... which colour to choose? cheers Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted May 15, 2012 Report Share Posted May 15, 2012 I am due for a new rear sprocket anyway as i noticed last weekend that i have several chipped teeth on my rear sprocket, which is a 42. Just to clarify, with the style of riding we have here in competitions there is very minimal 'trail' riding between sections (sometimes getting to each section is harder than the sections themselves ) and i don't think i've ever used 5th gear in the almost 12 months ive owned it. I occasionally use 4th just to give it a go but almost always immediately change back to 3rd because 4th labours too much. So realistically, i don't use 4th or 5th gear at all. When on my mate's 280 Ossa there's no problem as it has the extra grunt to just pull away without labouring. Also, i often find that 1st gear is too fast when i'm trying to navigate a tight section and second gear a tad too high for most climbs. I overcome this due the Sherco's suburb clutch which i feather through most sections... i love that clutch... Looks like i'll be ordering a 44 sprocket. Sounds like just the thing i need to suit the terrain we ride. I just hope the 44 sprocket makes enough of a difference because the 4% difference or whatever it is doesn't sound like much. I have the stock chain, is there likely to be any issues with the chain having enough length? And also the hardest part... which colour to choose? cheers You should always change front and rear sprocket together as a pair along with the chain. That way they all wear in together and last longer. A worn chain on a new sprocket will knacker it in no time plus as the front rotates possibly four times more than the rear if the rear is worn the front and chain most definately will be. Fronts are cheap enough as are chains so false economy to run worn parts on new. IMHO of course Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 15, 2012 Report Share Posted May 15, 2012 You should always change front and rear sprocket together as a pair along with the chain. That way they all wear in together and last longer. A worn chain on a new sprocket will knacker it in no time plus as the front rotates possibly four times more than the rear if the rear is worn the front and chain most definately will be. Fronts are cheap enough as are chains so false economy to run worn parts on new. IMHO of course Totally true ! IMHO Just a waste of $$$ not to do it all at the same time. Glenn Quote Link to comment Share on other sites More sharing options...
copemech Posted May 16, 2012 Report Share Posted May 16, 2012 I am due for a new rear sprocket anyway as i noticed last weekend that i have several chipped teeth on my rear sprocket, which is a 42. Just to clarify, with the style of riding we have here in competitions there is very minimal 'trail' riding between sections (sometimes getting to each section is harder than the sections themselves ) and i don't think i've ever used 5th gear in the almost 12 months ive owned it. I occasionally use 4th just to give it a go but almost always immediately change back to 3rd because 4th labours too much. So realistically, i don't use 4th or 5th gear at all. When on my mate's 280 Ossa there's no problem as it has the extra grunt to just pull away without labouring. Also, i often find that 1st gear is too fast when i'm trying to navigate a tight section and second gear a tad too high for most climbs. I overcome this due the Sherco's suburb clutch which i feather through most sections... i love that clutch... Looks like i'll be ordering a 44 sprocket. Sounds like just the thing i need to suit the terrain we ride. I just hope the 44 sprocket makes enough of a difference because the 4% difference or whatever it is doesn't sound like much. I have the stock chain, is there likely to be any issues with the chain having enough length? And also the hardest part... which colour to choose? cheers I agree that two teeth on the rear is not a tremendous difference, yet more a tradeoff. The stock gearing on a 125 is 9/44 as an example, yet they like to rev a bit more. If you really do not need the top speed of 5th gear, you could experiment cheaply with a 9t front just to see how things feel and find a balance there before dishing out for the whole kit. Chain fitment can be a pain, as most years use a half link and you may need to cut it out to drop a tooth on front. Depending upon what floats your boat, then decide, A 9t front def slows the bike and narrows the ratios, use 4th with the most ease for sure. Quote Link to comment Share on other sites More sharing options...
samy Posted May 16, 2012 Report Share Posted May 16, 2012 Thanks for the info guys! cheers Quote Link to comment Share on other sites More sharing options...
