restricting power on a 50cc
mickmc
Hi i have just bought a gas gas 50 txt, i want to restrict the power so my lad doesn't go wizzing off, can you buy anything to restrict the power until he gets used to it, he's not been on it yet, it's a xmas pressie he doesn't have a clue we have it :D
any help appreciated
Mick
Mick
You might be able to install a short piece of tubing over the throttle cable - between the slide and the cap that would limit the movement of the slide. You would have to take the top off the carb and find a piece of tubing that was just a bit larger than the cable end - and trim it to length before installing it over the cable. It might be a bit of a juggling act to get everything installed with the tiny size of the slide and carb.
