casperrasper Posted November 14, 2011 Report Share Posted November 14, 2011 hi there anyone got any ideas how to get the little allen key bolt what olds clutch basket on out .it is rounded off cant get it out with spit key or allen key ...cheers,,, Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 14, 2011 Report Share Posted November 14, 2011 "carefully" put a slot for screwdriver with a dremel, or similar. Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 14, 2011 Report Share Posted November 14, 2011 Just drill out the head, remove the basket. The rest of the bolt will come right out. You can run it without a bolt, but if you insist on a bolt get the correct one because it is an oil passage. Quote Link to comment Share on other sites More sharing options...
monty_jon Posted November 14, 2011 Report Share Posted November 14, 2011 (edited) Drill it out (put some grease on the drill to stop the swarf) you can get a new cap screw off ebay Don’t use any cap screw as they have a shallow head & a breather hole See link: BOLT Edited November 14, 2011 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
casperrasper Posted November 14, 2011 Author Report Share Posted November 14, 2011 cheers i will try with drill .thanks all...... Quote Link to comment Share on other sites More sharing options...
arnoux Posted November 14, 2011 Report Share Posted November 14, 2011 Put a lump of grease on the bolt head before drilling. This will lubricate the drill bit, but more importantly catch the swarf from drilling. As stated by others the bolt has a hole down the centre, and you don't want metal filings getting into the transmission on the other side. Drill bolt remove clutch basket remove remainder of bolt shaft replace clutch and replace bolt - part number Mt280232081 (always use the genuine bolt). Quote Link to comment Share on other sites More sharing options...
jse Posted November 14, 2011 Report Share Posted November 14, 2011 hi there anyone got any ideas how to get the little allen key bolt what olds clutch basket on out .it is rounded off cant get it out with spit key or allen key ...cheers,,, You could try a T-25 Torx bit on a short extension and then unscrew it out. Tapping the bit into the head of the capscrew will help break the bond. As mentioned, be sure to use a new OEM capscrew and a new Allen wrench or an old one with 5mm cut off the end. Jon Quote Link to comment Share on other sites More sharing options...
ham2 Posted November 14, 2011 Report Share Posted November 14, 2011 ........... Tapping the bit into the head of the capscrew will help break the bond. ...... Jon I've observed this procedure first hand several times...it helps to avoid the rounded head in the first place ( not trying to sound like a smart 4r5e just trying to help for the next time around). That little bolt is well buried on the Pros Quote Link to comment Share on other sites More sharing options...
jse Posted November 14, 2011 Report Share Posted November 14, 2011 I've observed this procedure first hand several times...it helps to avoid the rounded head in the first place ( not trying to sound like a smart 4r5e just trying to help for the next time around). That little bolt is well buried on the Pros You're right, it really does help, especially when one comes across that weird capscrew down in the hub hole. The capscrew is shaved down (and drilled to allow the trans to vent) to help clear the top hat servo cylinder so there is very little area for the Allen to "bite" into and if an old, worn Allen wrench is used they strip in no time. I always give the extention a tap with a small hammer before taking that capscrew out. Jon Quote Link to comment Share on other sites More sharing options...
casperrasper Posted November 15, 2011 Author Report Share Posted November 15, 2011 cheers for all suggestions i will post when i have had chance to do hit .... Quote Link to comment Share on other sites More sharing options...
casperrasper Posted November 15, 2011 Author Report Share Posted November 15, 2011 just done hit drilled head off clutch popped off with a bit of pressure cheers all................. Quote Link to comment Share on other sites More sharing options...
