mcman56 Posted November 17, 2011 Report Share Posted November 17, 2011 Does Beta specify a squish clearance for the Rev 3? They do offer base gaskets in different thicknesses. Quote Link to comment Share on other sites More sharing options...
rlracer Posted November 17, 2011 Report Share Posted November 17, 2011 Yes, Go to American Beta, I believe its under SUPPORT, you will find a service manuel. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted November 17, 2011 Author Report Share Posted November 17, 2011 Yes, Go to American Beta, I believe its under SUPPORT, you will find a service manuel. I found one for an evo but not Rev3. I wonder if they are the same? It is kind of odd to do that with a straight edge. I have always seen solder. Quote Link to comment Share on other sites More sharing options...
rlracer Posted November 18, 2011 Report Share Posted November 18, 2011 Same motor. Quote Link to comment Share on other sites More sharing options...
hrc1 Posted November 18, 2011 Report Share Posted November 18, 2011 1mm - 1.5 would be about std. more for softer engine. Less for more go.. 1 Quote Link to comment Share on other sites More sharing options...
jse Posted November 18, 2011 Report Share Posted November 18, 2011 1mm - 1.5 would be about std. more for softer engine. Less for more go.. That's generally where I set my engines. If you want to be super accurate, use two pieces of soft solder, front and back, which will compensate for piston rock and give a more consistant measurement. Jon Quote Link to comment Share on other sites More sharing options...
liviob Posted November 21, 2011 Report Share Posted November 21, 2011 (edited) Beta does offer a thin base gasket. Its availiable through the American Beta website or your local dealer. http://www.americanbeta.com/beta-trials-accessories.html Edited November 21, 2011 by Liviob Quote Link to comment Share on other sites More sharing options...
