taylo63 Posted November 21, 2011 Report Share Posted November 21, 2011 Hi All I have a 75 Cota 247 which on the whole runs very well.but smokes excessively ( even for a 70's twostroke). I am thinking that it could be a crankshaft oil seal? The reason I think so is because when i remove the spark plug and smell it I can smell gearbox oil. So...assuming it is a crankshft oil seal has anyone had first hand experience of replacing one? I assume the oil seal is on the clutch side? Do you require any specialised tools and is it something that could be done with a bit of mechanical knowledge.. Any comments would be most welcome Regards Quote Link to comment Share on other sites More sharing options...
bashplate Posted November 22, 2011 Report Share Posted November 22, 2011 Hi All I have a 75 Cota 247 which on the whole runs very well.but smokes excessively ( even for a 70's twostroke). I am thinking that it could be a crankshaft oil seal? The reason I think so is because when i remove the spark plug and smell it I can smell gearbox oil. So...assuming it is a crankshft oil seal has anyone had first hand experience of replacing one? I assume the oil seal is on the clutch side? Do you require any specialised tools and is it something that could be done with a bit of mechanical knowledge.. Any comments would be most welcome Regards it does sound like it's pulling the gearbox oil through the seal. i did my 325 bulto crank seals years ago, and once you got the mag off one side and the primary drive off the other, it was just a matter of unbolting a small seal housing off the main cases and popping the new seals in. would think the monty would be a similar set up. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 23, 2011 Report Share Posted November 23, 2011 Monty primary drive gear is on a taper which can be very difficult to separate. There are previous postings on the ways people have got the gear off. Yes the seal holder is just like a Bultaco. Quote Link to comment Share on other sites More sharing options...
