mur Posted November 22, 2011 Report Share Posted November 22, 2011 hi guys going to fit a new tyre soon ,i notice i only have one rim lock on the rear tyre is this OK i have not experienced any slip on the tyre (sherpa 1976) regards Murray Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 22, 2011 Report Share Posted November 22, 2011 hi guys going to fit a new tyre soon ,i notice i only have one rim lock on the rear tyre is this OK i have not experienced any slip on the tyre (sherpa 1976) regards Murray Two is standard these days, no problem to fit another one, usually about 120 degrees between each rim lock and valve. Look carefully before you drill the rim that it's not at the joint, and also that you will have enough space to get a spanner/socket on the nut. Quote Link to comment Share on other sites More sharing options...
mur Posted November 22, 2011 Author Report Share Posted November 22, 2011 Two is standard these days, no problem to fit another one, usually about 120 degrees between each rim lock and valve. Look carefully before you drill the rim that it's not at the joint, and also that you will have enough space to get a spanner/socket on the nut. well thanks for that speedy reply i shall get one right away i think threr is a hole already there kind regards murray Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 22, 2011 Report Share Posted November 22, 2011 Check the width of the rim before you order the rim lock as they come in two sizes, should be marked on the side , probably 1.85. Ross You can get them here http://www.trialsbits.co.uk/index.php?cPath=94_166 Quote Link to comment Share on other sites More sharing options...
