trialsbike Posted November 28, 2011 Report Share Posted November 28, 2011 I am restoring my Ossa 350 gripper it is nearing completion it will have lights, but i desperatelly need a wiring diagram to help, or we are stuck, please can anyone help me. paul@direct-energy.co.uk Quote Link to comment Share on other sites More sharing options...
stecks Posted November 28, 2011 Report Share Posted November 28, 2011 does this help...? OSSA Wiring Diagram its a start if it isn't quite right... Peter Quote Link to comment Share on other sites More sharing options...
alainp59 Posted February 24, 2012 Report Share Posted February 24, 2012 Hi. Have a look here : file:///D:/b%C3%A9cannes/OSSA/Ossa...%20Workshop%20Manual%20Five%20Speed%20Models/OSSA%20works%20manual.htm Or this one : Quote Link to comment Share on other sites More sharing options...
jojotut Posted April 20, 2012 Report Share Posted April 20, 2012 Hi do you have a workshop manual on this bike, Is it a TR80? I have one of these and need information on it as I will be undertaking a full rebuild. Thanks Quote Link to comment Share on other sites More sharing options...
woody Posted April 20, 2012 Report Share Posted April 20, 2012 Don't think there is a full manual for them, but regards the engine, it is essentially the same as the MAR for which there is a Clymer manual. there is little difference in the bottom end of both engines, they share the same design. The Gripper has no cush drive on clutch but has a counter weight which the MAR doesn't and needle rollers on layshaft (as per later MAR) but the rebuild principles and considerations are the same. Hardest thing is the gearbox shimming and removing the taper fit sleeve that the clutch side crank sprocket sits on. It needs a tool or you have to improvise and make one. The Clymer covers models up to about 1979 and details the shimming process (if you can make any sense of it) Todotrial.com Classic has a parts manual/diagram for the Gripper. Section 10 on the index on the left side of the home page. Quote Link to comment Share on other sites More sharing options...
alainp59 Posted April 21, 2012 Report Share Posted April 21, 2012 (edited) Look here : http://hem.spray.se/manyb/ There is no special manual for the TR80. As I know... I really doesn't know what happened to the link i gave you in my last post !!! Edited April 21, 2012 by AlainP59 Quote Link to comment Share on other sites More sharing options...
