scorpa front wheel fitment
farjazz
hi i have recently bought a set of 04 scorpa forks for a project i need a front wheel for them
does anyone know if a gasgas pro wheel will fit as they have same bearing setup i think also is the offset the same
thanks
i have 06 scorpa wheels in my rev3 i had to change front bearings as inside diameter was larger but outside is the same ,the disc was in a simular position but you can play with disc via washers front or behind ,you can also have spacers machined down to centralize wheels or a wider one made if you take to a machine shop
