redstormv Posted November 29, 2011 Report Share Posted November 29, 2011 Hi, New to modern trials bikes and found needing replacement seals (5) for the rear caliper. Can I just buy the seals or do I have to buy a service kit and if so, where from? My daughter went for a little potter around on Sunday she's not ridden a bike of any description since she was 7, about 20 years ago. Watched her come back down the field and was shocked to see a lot of smoke coming from the back if the bike. (Too much 2-stroke? Mixture problem?) When she pulled up all became clear. She'd inadvertently had her foot on the rear brake as she'd ridden round! I knew brakes could get hot, even glow, I've seen it on road bikes. This wasn't just hot, it was on fire, yellow, green and many other coloured flames all licking out from the caliper! Pulled the caliper down last night, only a drop of fluid left in it or the brake pipe. The pads are shot and all the seals are crispy. Think the fluid and copper back plates of t huh e pads explains the 'pretty' flames. Luckily, the disc is blued but not warped and the pistons and caliper look to be OK and have cleaned up well. Any advice appreciated. Quote Link to comment Share on other sites More sharing options...
benwall Posted November 29, 2011 Report Share Posted November 29, 2011 most parts can be found here http://trialstribulations.net/index.php?main_page=index&cPath=39&sort=20a&page=1 i use them all the time there ofical beta parts Quote Link to comment Share on other sites More sharing options...
redstormv Posted November 29, 2011 Author Report Share Posted November 29, 2011 Cheers Ben? I found them t'other night when browsing through. I mustn't have looked hard enough thy h or searched for the right thing. Was using beta rev3 seals or similar. Looks to be AJP Late type 2 pot rear brake caliper rebuild kit I need but will check with them tomorrow. Quote Link to comment Share on other sites More sharing options...
redstormv Posted December 7, 2011 Author Report Share Posted December 7, 2011 Well after just short of Quote Link to comment Share on other sites More sharing options...
fhtrucker Posted December 8, 2011 Report Share Posted December 8, 2011 i have similar play on both discs on my little used 2008 rev3 and thought the bolts were slack, but on checking it, bolts were tight. Does seem there is a bit of play between the disc and the spacers. Meant to ask around myself to see if this is standard or not. Quote Link to comment Share on other sites More sharing options...
stevel Posted December 8, 2011 Report Share Posted December 8, 2011 Play in the discs is normal, they are 'floating' discs Quote Link to comment Share on other sites More sharing options...
redstormv Posted December 8, 2011 Author Report Share Posted December 8, 2011 Cheers Steve, I thought of that but would have expected it to be lateral play like road bikes ie toward & away from the hub. This play is in the opposite plane ie. clockwise / anti clickwise as you look at the disc. It doesn't appear to have an adverse affect on the braking, just don't want to cause any further problems. Quote Link to comment Share on other sites More sharing options...
mikethompson Posted December 9, 2011 Report Share Posted December 9, 2011 My Rev 3`s brakes had a lot of play in the front and rear discs. They used to clunk when i applied the brakes. I replaced the top hat washers and springs and they are now like new. Got the parts from trials and tribulations mail order. Regards Mike Quote Link to comment Share on other sites More sharing options...
redstormv Posted December 10, 2011 Author Report Share Posted December 10, 2011 Cheers Mike, Looks like T&T could be getting another order soon then. Quote Link to comment Share on other sites More sharing options...
