steam Posted December 2, 2011 Report Share Posted December 2, 2011 Any reason why I cant use Avgas in my Premix for a 2008 rev3 2t? I am trying to stop what seems like pinking on a light throttle. Quote Link to comment Share on other sites More sharing options...
technowaldo Posted December 2, 2011 Report Share Posted December 2, 2011 TRY SHELL V POWER STOPPED MY 06 PINKING Quote Link to comment Share on other sites More sharing options...
furse Posted December 2, 2011 Report Share Posted December 2, 2011 I would try the Shell V Power first as Technowaldo said, But yes people have used AV and Blue gas but not sure if it would help your pinking. Quote Link to comment Share on other sites More sharing options...
pindie Posted December 2, 2011 Report Share Posted December 2, 2011 Pinking or piston rattle? Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted December 2, 2011 Report Share Posted December 2, 2011 where do you get this generally speaking, avgas that is ? Quote Link to comment Share on other sites More sharing options...
copemech Posted December 3, 2011 Report Share Posted December 3, 2011 where do you get this generally speaking, avgas that is ? Local small private airfield! Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted December 3, 2011 Report Share Posted December 3, 2011 that was the lines along which I was thinking! Quote Link to comment Share on other sites More sharing options...
0007 Posted December 3, 2011 Report Share Posted December 3, 2011 Increasing the octane will likely cause a loss of power I noticed my 07 is a bit sensitive to fuel, if it's even 2 weeks old I get a detonation at higher rpm with mid throttle openings Fresh fuel is a lot better but is still has a minor tendency to ping Richer on the needle helped a bit, I will try richer on the main, I suspect it's just the wrong needle or needle jet that is the cause Quote Link to comment Share on other sites More sharing options...
