gas gas clutch help
zaccyboy
Hi Guys and Gals, The question is.. just acquired a gassa 250 txt pro on a 05. The clutch has been redone about 3 weeks ago by previous owner ( done by shop )The clutch feels very tight at the lever ( pulling lever in). Any ideas on this would be appreciated.
thanks all.
thanks all.
clutch pack to thick
  On 12/4/2011 at 8:19 PM, laser1 said:
If you dont put the thick plate in 1st, you will get a light pull. (and maybe some slip)
Sorry - Mis read your post. Thought you said light - not tight. Curt is right - 06+ has a lighter spring.
