drake Posted December 6, 2011 Report Share Posted December 6, 2011 I Find the clutch on my 2003 290 a bit on or off if you know what i mean. I put this down to using ATF. I have just changed to regular 10/40 and noticed a small differance. My question is has anyone tried DOT 5? Quote Link to comment Share on other sites More sharing options...
chewy Posted December 6, 2011 Report Share Posted December 6, 2011 I put 3 "lighter " springs into the assy. ..lighter ...more feel.. Quote Link to comment Share on other sites More sharing options...
drake Posted December 6, 2011 Author Report Share Posted December 6, 2011 Where do you get lighter springs from, and why 3 not 5? Quote Link to comment Share on other sites More sharing options...
chewy Posted December 6, 2011 Report Share Posted December 6, 2011 Flexo springs (google) sorry cant recall part no. you will need to tell them O.dia. I. dia. length, (physical size to fit in place) from memory I wanted c. 80% of the rate and in the end 3 off of what they had on shelf was what did it. There was a min order but I had lumped it in with an other order. I can't dig the invoice up @cause it's with the accountant at moment. Worth doing the work as it made clutch really sweet.. check out previos Sherco forums. Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 6, 2011 Report Share Posted December 6, 2011 Gday, Dot 5 is brake fluid. Dont use that in your gearbox... Why not try the Beta clutch fix in the beta section? I cant see why it wont help. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
rosey Posted December 6, 2011 Report Share Posted December 6, 2011 If you want to reduce the switchiness just move the master cylinder further inwards in the bars... You will then use the lever nearer the end and it'll be lighter and more progressive... OK you may have to set the bite point to suit. Quote Link to comment Share on other sites More sharing options...
drake Posted December 6, 2011 Author Report Share Posted December 6, 2011 Gday, Dot 5 is brake fluid. Dont use that in your gearbox... Why not try the Beta clutch fix in the beta section? I cant see why it wont help. Cheers, Stork Mmm I thought that as well, but read it on here while doing a search? Quote Link to comment Share on other sites More sharing options...
