mill9898 Posted December 9, 2011 Report Share Posted December 9, 2011 i am having problems with my beta 99 fan it will not work ,does anyone have a manual for one ? Quote Link to comment Share on other sites More sharing options...
nevilletanner Posted December 9, 2011 Report Share Posted December 9, 2011 i am having problems with my beta 99 fan it will not work ,does anyone have a manual for one ? yep i sure have , message me your e-mail addy. have you checked the fan via connecting it up to a 12v battery ? have you shorted out the two wires to the thermo switch ( brass bolt with two wires going to it at the top of the cylinder) good place to start, then you will know where to start looking for a fault. Quote Link to comment Share on other sites More sharing options...
mill9898 Posted December 11, 2011 Author Report Share Posted December 11, 2011 (edited) i have tried joining the two wires from the thermostat that didnt work, and my email is jacobmiller39@aol.com , and thanks alot neville and your inbox is full Edited December 11, 2011 by mill9898 Quote Link to comment Share on other sites More sharing options...
nevilletanner Posted December 11, 2011 Report Share Posted December 11, 2011 i have tried joining the two wires from the thermostat that didnt work, and my email is jacobmiller39@aol.com , and thanks alot neville and your inbox is full got your email, manual and schematic with part numbers have been sent. you need to try the fan with a 12v DC supply, either from a car battery or a power supply, until then you cant tell if its the fan or any other component, if the fan works check the following. earth connection from the fan or earth connection to the thermostat switch ( depends on how it is wired ) +12v dc feed to the fan or the thermostat ( again depents on which way it is wired ) use a multimeter or a 12v bulb will do. if thre is 12v then it has to be a earthing issue if not :- check there is 50v AC on the yellow wire from the stator to the rectifer , if there is go for a new rectifer (easy to make with a couple of components from Maplins) if there is no voltage on the yellow wire then its time to get the stator re-wound. Quote Link to comment Share on other sites More sharing options...
