ossa 250 gripper jets
pygar
Have just been given a mikuni carb could anybody tell me which jets to use for my 250 ossa gripper.
Thanks in advance
Robin
Robin, look on page 2 in twinshocks then -any ossa gripper guru`s out there, you will see my mikuni settings
note though my carb is a 28mm. Steve.
Thanks for the sensible replay steve,have seen post,my carb is a 26mm and bike a 250 but should give me a starting point.
thank again
Robin, my gripper is also a 250 but it has a MAR piston (2mm extra) so i think its 244cc i also put the window in the back of the piston. I put the mikuni on because i wanted the revs to pickup quicker, i have also reduced the flywheel weight on the cush drive, then also drilled some big holes in the clutch basket. I feel if i go anymore i will loose its grip low down the revs.
steve.
