pygar Posted December 13, 2011 Report Share Posted December 13, 2011 Have just been given a mikuni carb could anybody tell me which jets to use for my 250 ossa gripper. Thanks in advance Robin Quote Link to comment Share on other sites More sharing options...
reggie Posted December 13, 2011 Report Share Posted December 13, 2011 I think you will need a main jet and a pilot jet. Quote Link to comment Share on other sites More sharing options...
bashplate Posted December 13, 2011 Report Share Posted December 13, 2011 reggie.....i think he was hoping for the jet sizes Quote Link to comment Share on other sites More sharing options...
bisby Posted December 14, 2011 Report Share Posted December 14, 2011 Have just been given a mikuni carb could anybody tell me which jets to use for my 250 ossa gripper. Thanks in advance Robin Robin, look on page 2 in twinshocks then -any ossa gripper guru`s out there, you will see my mikuni settings note though my carb is a 28mm. Steve. Quote Link to comment Share on other sites More sharing options...
pygar Posted December 14, 2011 Author Report Share Posted December 14, 2011 (edited) Thanks for the sensible replay steve,have seen post,my carb is a 26mm and bike a 250 but should give me a starting point. thank again Edited December 14, 2011 by pygar Quote Link to comment Share on other sites More sharing options...
bisby Posted December 14, 2011 Report Share Posted December 14, 2011 Thanks for the sensible replay steve,have seen post,my carb is a 26mm and bike a 250 but should give me a starting point. thank again Robin, my gripper is also a 250 but it has a MAR piston (2mm extra) so i think its 244cc i also put the window in the back of the piston. I put the mikuni on because i wanted the revs to pickup quicker, i have also reduced the flywheel weight on the cush drive, then also drilled some big holes in the clutch basket. I feel if i go anymore i will loose its grip low down the revs. steve. Quote Link to comment Share on other sites More sharing options...
