montesa love
motomanandy
I knew i wasnt alone....the curves....that tail pipe,and the awkwardness of the choke lever.. :wub:
Aw c'mon, Mr Picky..drill a hole through the lever and put a tiny cable tie through it. B)
Can't help you with the fuel tap though :huh:
What about that fiddly little oil filler that allways oozes oil when you try to top her up,,,
mines also suffering from main bearing failure, so you get a fantastic tingeling vibration feed back :unsure:
would not swap it for the world
