Silly question - 199 oil drain ?
smelling123
The 199A that I sold last week had 2 gearbox drain plugs. I don't think that it was meant to have 2 but it did. It had the normal one that Legs mentioned although mine had a 19mm spanner size head (probably explains why I had to repair the thread with a helicoil insert). It also used to lose the gearbox oil if the primary drive drain plug was removed. The gearbox oil used to pour out through the threaded hole that the primary drive drain plug screws into.
