smelling123 Posted December 22, 2011 Report Share Posted December 22, 2011 Hi, Where is the gearbox oil drain on the 199a Bult? Doesnt seem to be in the same place as my 190 - or am I cracking up... thanks in advance.. Quote Link to comment Share on other sites More sharing options...
legs Posted December 22, 2011 Report Share Posted December 22, 2011 199a Gear box drain is the 13mm spanner size bolt under front sprocket goes in side of engine. Quote Link to comment Share on other sites More sharing options...
smelling123 Posted December 22, 2011 Author Report Share Posted December 22, 2011 199a Gear box drain is the 13mm spanner size bolt under front sprocket goes in side of engine. Many thanks sorted. Quote Link to comment Share on other sites More sharing options...
raffles Posted December 23, 2011 Report Share Posted December 23, 2011 The 199A that I sold last week had 2 gearbox drain plugs. I don't think that it was meant to have 2 but it did. It had the normal one that Legs mentioned although mine had a 19mm spanner size head (probably explains why I had to repair the thread with a helicoil insert). It also used to lose the gearbox oil if the primary drive drain plug was removed. The gearbox oil used to pour out through the threaded hole that the primary drive drain plug screws into. Quote Link to comment Share on other sites More sharing options...
