scotty300 Posted December 23, 2011 Report Share Posted December 23, 2011 Just installed a new kickstart quadrant on my 09 300 pro. The shaft is in place with the spring loaded. When I push the kick start down the quadrant engages with the idler gear and turns it, however on the return the quadrant and the idler gear do not dis-engage. Any suggestions? Cheers Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 24, 2011 Report Share Posted December 24, 2011 I`ve done it before. I cannot remember the details but your assembly is backwards I believe. Sorry I can`t give you the specifics. Quote Link to comment Share on other sites More sharing options...
jse Posted December 24, 2011 Report Share Posted December 24, 2011 Just installed a new kickstart quadrant on my 09 300 pro. The shaft is in place with the spring loaded. When I push the kick start down the quadrant engages with the idler gear and turns it, however on the return the quadrant and the idler gear do not dis-engage. Any suggestions? Cheers Try: http://www.trialspartsusa.com/tech.html and click on the link- "GASGAS Pro Technical Bulletin", that might help. Jon Quote Link to comment Share on other sites More sharing options...
