Bendy Frame question!
jonesytwo
Guys
Thinking of getting a fantic pro TS, but am a little concerned by the frame issues they seemed to have, so any thoughts on questions below appreciated.
Is it a given that the frame on the 125/240/300 pro models will give at the head tube area at some stage,or is it dependent on whether the bike has had a hard life?
Were later "pro frames" modified to stop this happening and if so does anyone know how to tell a later modified frame from one of the early ones.
thanks
Starting sometime in the 240's production run the factory doubled the down tubes,Tube in a tube , for more strenght , But I don't think you can tell when looking at a frame , as they still bent/cracked...
These days you will most likley want to steepen the fork angle a little anyways ,so a crack or distortion is no big deal...
If your anywhere nere Classic trials in the UK , contact them , as Chris has a chassis jig set up to make them right ,and knows the time proven method of strengtening that weak spot :) And can set one up to compete with the modern boys if you so desire ...
Glenn B)
Guys
thanks
I know from dr agrati that fantic made 24,000 odd pro frames, either 125', 200 or 240. The first 5000 were single tube design. If you get a fantic without cracks at the headstock webbing, you are unlikely ti crack it in todays level. Even the miller rounds. Most however will be cracked even if to a lesser extent. This is an easy fix. More difficult but still repairable are smashed bottom tubes. I have changed both tubes on one frame and it also turned out to be very relable. The fantic really does over no worries so your concerns can be covered
