Fork service
theboo
Hi seals have gone gave them a really good clean and then pumped a couple of times and oil showing, clutch is odd at the start of the day clutch not fully engaging so i alter the lever a little but towards the end of the day i have to let the lever out again,
Its normal for oil to come out after cleaning. Do it a couple of times, keep pumping the forks and it should improve.
Is your free play on the clutch at about 3mm? Sounds like its getting hot and expanding giving you issues. Change oil first as well?
