theboo Posted December 26, 2011 Report Share Posted December 26, 2011 Hi can anyone recomend anyone in yorkshire who service,s forks, seals went today require newseals etc, plus have a slight clutch problem thanks Quote Link to comment Share on other sites More sharing options...
sfield Posted December 26, 2011 Report Share Posted December 26, 2011 Depends where in Yorkshire, North, West, South, East. There are manywho could do this. Quote Link to comment Share on other sites More sharing options...
theboo Posted December 26, 2011 Author Report Share Posted December 26, 2011 South to north would be best Quote Link to comment Share on other sites More sharing options...
sfield Posted December 26, 2011 Report Share Posted December 26, 2011 Trials UK in Horsforth would seem best located for you. Never had service work done by them, as too far from me. Working from comments of others. Quote Link to comment Share on other sites More sharing options...
pindie Posted December 27, 2011 Report Share Posted December 27, 2011 You could clean the seals first and see if it helps? There on videos on You tube - Cleaning fork seals. This works for me. Whats your clutch issue? Have you tied an oil change? Quote Link to comment Share on other sites More sharing options...
theboo Posted December 27, 2011 Author Report Share Posted December 27, 2011 Hi seals have gone gave them a really good clean and then pumped a couple of times and oil showing, clutch is odd at the start of the day clutch not fully engaging so i alter the lever a little but towards the end of the day i have to let the lever out again, Quote Link to comment Share on other sites More sharing options...
pindie Posted December 27, 2011 Report Share Posted December 27, 2011 Its normal for oil to come out after cleaning. Do it a couple of times, keep pumping the forks and it should improve. Is your free play on the clutch at about 3mm? Sounds like its getting hot and expanding giving you issues. Change oil first as well? Quote Link to comment Share on other sites More sharing options...
