trialtrial Posted December 29, 2011 Report Share Posted December 29, 2011 He guys, got the ty250 mono running. One of the things I did was cleaned up and re-greased the kick starter. But now it wont sit nicely stowed away while riding - it just creeps out. Suggestions? thanks Quote Link to comment Share on other sites More sharing options...
searay175 Posted December 29, 2011 Report Share Posted December 29, 2011 I assume you did not loose the detent ball. I had the same results with my ty350 mono which has a well worn kick starter. I tried setting it back on the shaft so it would be in a upright position so my short legs could access it easier but it made it want to swing out also. I had to move it forward so the weight of it would keep it in place. I also strechted the detent spring slightly to put more pressure on the ball. Quote Link to comment Share on other sites More sharing options...
trialtrial Posted December 29, 2011 Author Report Share Posted December 29, 2011 I assume you did not loose the detent ball. Thats probably the issue.... Quote Link to comment Share on other sites More sharing options...
