bondy Posted December 31, 2011 Report Share Posted December 31, 2011 hi all ive had my frame powder coated .and he has powder coated the coil bracket will it be enough earth if i just take the paint from inside the holes were the bolts go throw? allso ive asked this before but have forgot when i put the fork tubes back in the legs .and tighten the bolt up at the botom ive been told to use a copper washer will this stop it leaking.and how many do i need for each leg? one or more? Quote Link to comment Share on other sites More sharing options...
copemech Posted January 1, 2012 Report Share Posted January 1, 2012 hi all ive had my frame powder coated .and he has powder coated the coil bracket will it be enough earth if i just take the paint from inside the holes were the bolts go throw? allso ive asked this before but have forgot when i put the fork tubes back in the legs .and tighten the bolt up at the botom ive been told to use a copper washer will this stop it leaking.and how many do i need for each leg? one or more? You gotta sand or grind down to metal for a good earth. Yes copper washers work, one each. Quote Link to comment Share on other sites More sharing options...
bondy Posted January 1, 2012 Author Report Share Posted January 1, 2012 You gotta sand or grind down to metal for a good earth. Yes copper washers work, one each. thanks Quote Link to comment Share on other sites More sharing options...
