rontheyank Posted January 2, 2012 Report Share Posted January 2, 2012 Send the stator to west country windings, they will tell you if its any good and repair it if necessary. Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 3, 2012 Report Share Posted January 3, 2012 Hi Lee, the green wire goes to the box at the bottom right hand corner of the stator plate, is this the trigger coil? I thought this was the "pick up". Took the stator off and tested the trigger coil (green wire) for ohms resistance it read 39.6. Do you think this low reading could be the cause? Thanks in advance. Trigger and pick up are the same. The reading is fine Quote Link to comment Share on other sites More sharing options...
