magicmark1968 Posted January 1, 2012 Report Share Posted January 1, 2012 Hi, I am new and have recently purchased a Gas Gas 50 txt boy for my son. The clutch fluid is low and needs topping up the owners manual says "Warning: Use the recommended oil. See quick guide to maintenance, page 8" Problem is no clutch fluid is mentioned on page 8. Is this just ordinary brake/clutch fluid ? Thanks Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted January 1, 2012 Report Share Posted January 1, 2012 Hi, I am new and have recently purchased a Gas Gas 50 txt boy for my son. The clutch fluid is low and needs topping up the owners manual says "Warning: Use the recommended oil. See quick guide to maintenance, page 8" Problem is no clutch fluid is mentioned on page 8. Is this just ordinary brake/clutch fluid ? Thanks I don't know if it is correct but I used normal dot4 brake fluid in mine. Quote Link to comment Share on other sites More sharing options...
idp Posted January 2, 2012 Report Share Posted January 2, 2012 Hi, I am new and have recently purchased a Gas Gas 50 txt boy for my son. The clutch fluid is low and needs topping up the owners manual says "Warning: Use the recommended oil. See quick guide to maintenance, page 8" Problem is no clutch fluid is mentioned on page 8. Is this just ordinary brake/clutch fluid ? Thanks If the master cylinder cap is black it's DOT 4 If it's Dark green It's Mineral Oil only. LHM etc (citroen) Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 2, 2012 Report Share Posted January 2, 2012 pretty sure mine is mineral, think it depends on year of manufacture. Quote Link to comment Share on other sites More sharing options...
magicmark1968 Posted January 7, 2012 Author Report Share Posted January 7, 2012 Thanks for the replies DOT 4 now added. Quote Link to comment Share on other sites More sharing options...
